Hello Guest it is November 15, 2026, 09:23:52 PM
Author Topic: Mach3 Turn, can't jog, g-codes work normal  (Read 8916 times)
« on: February 01, 2018, 05:22:29 PM »
First of all i want to say hello to everyone because it is my first post. Second sorry for my bad english :/.
So i have a problem with Mach3 Turn, when i put my program with g-codes CNC works normally moves in every axis, but when i want to move it with keyboard it won't work, the jog control is not lit. I think that it is an issue with a program, i was tweaking my axis Z and Y point to compansate on a detail and one moment the jog on keyboard stoped working, also i can't jog in TAB menu or change any of the jog modes (previously one of switches was lit for cont. I think now zero). I tried restarting whole system and the problem persists.
Offline TPS
  •  2,627 2,627
Re: Mach3 Turn, can't jog, g-codes work normal
« Reply #1 on: February 02, 2018, 09:00:49 AM »
jog mode enebled ?
« Reply #2 on: February 04, 2018, 05:30:09 PM »
Long story short, simple returning to previous settings helped. But thanks for your input TPS i could not enable it.
