Hello Guest it is October 24, 2026, 05:29:37 PM
Author Topic: Lathe wizard scripts  (Read 14755 times)
« on: January 27, 2018, 10:25:06 PM »
I'm trying to find the scripts for the lathe wizards by Mach Motion.
Close as I can get is a file with ESCLuaR .. and that is all.
Are they somehow hidden, locked and protected ?
Russ
Re: Lathe wizard scripts
« Reply #1 on: January 28, 2018, 12:13:36 AM »
don't know about wizards but what about:
Mach4Hobby\Modules\AddOns\LatheCannedCycles
They are complied so you cant really see whats in them. I assume these sre the little suckers I'm having trouble loading from time to time.
« Reply #2 on: January 28, 2018, 12:40:16 AM »
Yup, that is where I was looking ... among other places.
On another point. I finally saw a popup when trying to restart after an attempted shutdown.
"Correct unload script error then restart"
Only saw it once.
« Reply #3 on: January 28, 2018, 06:17:08 PM »
I didn't have any luck finding those scripts either.  I wanted to tweak a couple of things.
Chad Byrd
« Reply #4 on: January 29, 2018, 05:03:26 PM »
I think what you guys are calling Wizards are in fact included in this module.
Modules are complied, you can't tweak it. You could write your own...
« Reply #5 on: January 29, 2018, 06:31:23 PM »
You mentioned "compiled" earlier.
If you write your own module, then compile it, can you un-compile it to edit it ? (must assume so)
Would it be password protected ? or what is the process ?
Thanks Craig,
Russ
« Reply #6 on: January 29, 2018, 06:52:30 PM »
no, you cannot by and large de-compile. In order to edit your code you need the source code, you edit it
and then a new 'compiled' version is made. Without the source code you can do nothing.
If you were writing a wizard for Mach4 to sell  you would not give your customers the source code,
just the compiled or executable code.
You might ask NFS for the source, I suspect they consider it proprietary code in which case they'll say no.
« Reply #7 on: January 29, 2018, 06:54:57 PM »
I have been told you can use the very rare substance 'Unobtainium' to de-compile code. LOL
« Reply #8 on: January 29, 2018, 06:55:31 PM »
Yeah.  Especially since MachMotion did the programming for the code.
Chad Byrd
« Reply #9 on: January 29, 2018, 07:02:27 PM »
That's exactly as I suspected. MachMotion contributed those. I'm sure they would have a say in it as well.
Thanks Craig, I learn a little each day.
It's fun, thanks for your time.
Russ
