Hello Guest it is October 23, 2026, 03:56:18 PM
Author Topic: Mach Motion Lathe Wizards Bug? Help.  (Read 28132 times)
Re: Mach Motion Lathe Wizards Bug? Help.
« Reply #10 on: January 31, 2018, 10:06:34 PM »
Found a ton of more bugs in Mach Motion Lathe Wizards.
The parting wizard crashed my tool, now I need another parting tool. No matter what you change the feedrate to it stays at 10 IPM and the RPM stays at what you have in the preferences, in my case 1800 RPMs.
And it locks up every so often. It also will get hung up and the settings won't change. So if you go to run a program and some of the gcode is not what you want and you go back to the wizard and change a value and update it, it doesn't update the Gcode when you generate it.
« Reply #11 on: January 31, 2018, 10:22:46 PM »
Could you post the offending code generated by the wizard along with the settings you entered?
« Reply #12 on: January 31, 2018, 10:44:19 PM »
I'd really like to duplicate/verify what you are describing.
But, I see from NFS ... Download the fully functional Demo, try it out, see if you like it .......
Then I try out the wizards and get this ....
As far as the wizards go, I guess ya gotta buy it to try it.  :)
« Reply #13 on: January 31, 2018, 10:47:06 PM »
rh, I'll do that tomorrow.
« Reply #14 on: January 31, 2018, 10:59:14 PM »
Oh and another bug, kind of. If I do multiple drill cycles in the same program only the first drill sequence moves the drill to the Z that was set in the wizards. After my carriage moves for a tool change to a different drill the carriage won't move back to the correct Z so it starts to peck drill about 2 inches in front of the part. It has the correct coordinates to drill to, but the starting Z is way off and other drills after that are that way too so I have to edit the gcode so as to not waste time having it drill air.
« Reply #15 on: January 31, 2018, 11:28:31 PM »
That sort of looks like a tool Z offset issue.
Can you verify that the offsets are configured and applied correctly for each tool ?
« Reply #16 on: February 01, 2018, 09:36:23 AM »
Peck drilling is a canned cycle that remains in effect until a G80 is issued.  Every time you make a move it will issue another peck cycle.  Check the code to see if a g80 is issued after each peck cycle.
HTH
RT
« Reply #17 on: February 01, 2018, 12:36:54 PM »
I'm with RT on that one... Make sure you're cancelling the Drill Cycle with G80.
Chad Byrd
« Reply #18 on: February 01, 2018, 05:49:38 PM »
@overloaded, it's not an offset issue as it still drills to the correct depth, just takes forever(s) ;-). I'm not cancelling anything. This is straight from the wizards. I'm doing 3 different drill cycles and compile them all within the wizard.
Here's the code:
N0000 (Machine type - MachMotion Lathe Canned Cycles)
N0005 (Filename: C:\Mach4Hobby\GcodeFiles\Drill and Turn.tap)
N0010 (Generated on 01/31/18 at 18:27:39)
N0015 %
N0020 G00 G40 G18 G54 G64 G80 G90.1 G99 G20 (Safe Start Block)
N0025 %
N0030 (Starting Gcode for Drilling Cycle: DrillingCycle-0)
N0035 %
N0040 G00 G40 G18 G54 G64 G80 G90.1 G99 G20 (Safe Start Block)
N0045 %
N0050 T0707 (Tool Change)
N0055 G98 (Feed per Minute)
N0060 G97 S1200 (Constant Speed)
N0065 M04 (Spindle Reverse)
N0070 M08 (Flood)
N0075 G00 X0.0000 Z0.0600
N0080 G83 X0 Z-1.7 R0.06 Q0.06 F5
N0085 G80
N0090 G00 X0.0000 Z0.0600
N0095 (End Gcode for Drilling Cycle: DrillingCycle-0)
N0100 (Starting Gcode for Drilling Cycle: DrillingCycle-1)
N0105 %
N0110 G00 G40 G18 G54 G64 G80 G90.1 G99 G20 (Safe Start Block)
N0115 %
N0120 T0505 (Tool Change)
N0125 G98 (Feed per Minute)
N0130 G97 S1100 (Constant Speed)
N0135 M04 (Spindle Reverse)
N0140 M08 (Flood)
N00145 G83 X0 Z-0.58 R0.06 Q0.08 F5
N0150 G80
N0155 G00 X0.0000 Z0.0600
N0160 (End Gcode for Drilling Cycle: DrillingCycle-1)
N0165 (Starting Gcode for Drilling Cycle: DrillingCycle-2)
N0170 %
N0175 G00 G40 G18 G54 G64 G80 G90.1 G99 G20 (Safe Start Block)
N0180 %
N0185 T0416 (Tool Change)
N0190 G98 (Feed per Minute)
N0195 G97 S700 (Constant Speed)
N0200 M04 (Spindle Reverse)
N0205 M08 (Flood)
N00210 G83 X0 Z-0.48 R0.06 Q0.08 F5
N0215 G80
N0220 G00 X0.0000 Z0.0600
N0225 (End Gcode for Drilling Cycle: DrillingCycle-2)
N0230 (Starting Gcode for Turning Cycle: TurnCycle-0)
N0235 ([Xi, Zi] = [1.25, 0]; [Xf, Zf] = [1.172, -1.5]; Z- Direction; OD)
N0240 G50 S4100 (Spindle Speed Cap)
N0245 (Roughing)
« Reply #19 on: February 01, 2018, 05:53:52 PM »
Here's a pic of the wizard entries and the resulting code for the messed up Parting Cycle. Also the pecking part doesn't work at all.
https://www.dropbox.com/s/rpofac3bgzev5oc/Mach%20Motion.JPG?dl=0
https://www.dropbox.com/s/uct90qjeuyivzj4/GCode.JPG?dl=0
