Hello Guest it is September 05, 2026, 09:44:24 PM
Author Topic: Which files in Mach3 contain the configuration settings?  (Read 10929 times)
« on: January 01, 2018, 01:21:41 AM »
I have reinstalled  after a disc crash to a newer version of Mach3 and need to transport the files of config. settings from another Mach3 program which I have on another PC. So I need to know which of the files in the Mach library that contain these settings and registration code.
Can anybody here help me whit this issue?
  •  9,368 9,368
Re: Which files in Mach3 contain the configuration settings?
« Reply #1 on: January 01, 2018, 01:29:50 AM »
Your config. is stored in <your profile> .xml (typically Mach3Mill.xml).
Your licence file is called Mach1Lic.dat
Both are in the Mach3 folder.
If you have any special Screen sets or Macros then these also need to be copied across.
« Reply #2 on: January 03, 2018, 09:08:50 AM »
It didn´t work with the latest version, So I had to install the version that end with .022 instead of the latest .066. Are there any differences between these or will the earlier version be just as good for me?
  •  9,368 9,368
« Reply #3 on: January 03, 2018, 09:10:19 AM »
Version .062 will be just fine - version 0.22 is old and may cause you problems, but try it and see.
« Last Edit: January 03, 2018, 09:15:43 AM by Tweakie.CNC »
« Reply #4 on: January 04, 2018, 07:25:02 PM »
With version .062 I could only get it to run in offline mode. If I tried to press the reset button, it wouldn´t turn to green. What could be the reason for that?
  •  9,368 9,368
« Reply #5 on: January 05, 2018, 12:32:32 AM »
Generally it would be that you have the active state for Estop configured incorrectly in Ports & Pins.
