Hello Guest it is October 22, 2026, 07:10:07 PM
Author Topic: Mach 3 Homing switches wiring with Gecko G540  (Read 12978 times)
« on: December 31, 2017, 02:38:34 AM »
After searching the various responses concerning the wiring of Homing Switches to a Gecko G540. I'm confused about switches that are designed to be run in a Normally Open Configuration when the Gecko PDF states that the G540 is designed to operate Homing Switches in a Normally Closed Configuration.
Is there a way to modify what Mach3 sees such as changing from Active High for Normally Closed to Active Low for Normally Open?
Offline TPS
  •  2,627 2,627
Re: Mach 3 Homing switches wiring with Gecko G540
« Reply #1 on: December 31, 2017, 04:23:12 AM »
Config -> Ports&Pins -> Input Signals -> Collum Aktive Low
« Reply #2 on: December 31, 2017, 12:23:45 PM »
Thanks for clarifying what I was assuming to be correct.
« Reply #3 on: January 19, 2018, 04:17:59 AM »
The problem with active low configuration is, If a wiring fault occurs you wont know until your head crashes into the table or boundaries. Active high is much safer and E-stops if there is a fault.
« Reply #4 on: January 19, 2018, 04:31:27 AM »
Not really a problem for homing switches as long as his e-stop and limits are normally closed.
Mike
« Reply #5 on: January 19, 2018, 05:29:44 AM »
Ok, for a brand newbie, I have the mechanics together(minus the limits switches) but there`s a difference between a homing switch and a limit switch?
« Reply #6 on: January 19, 2018, 07:27:28 AM »
Greetings !
There's a GREAT BIG section regarding this in the set-up manual ..... well worth a read, its well written and quite clear. Even for a brand newbie .... like I was.  :)
Russ
« Reply #7 on: January 19, 2018, 07:55:23 AM »
Haha - I knew there would be but I`m so newbie I wasn`t even sure where to look.
Thanks for the pointer. ;D
