Hello Guest it is October 20, 2026, 03:08:13 PM
Author Topic: Full Step to Microstepping  (Read 11702 times)
« on: July 05, 2007, 01:03:24 PM »
This is maybe a stupid question : I was working today with my newly built CNC in Full step . Everything is fine. I was engraving something to test with "WRITE" and  it was OK but not as perfect. Then  was gonna swich to microstepping because I wasn't quiet happy with the resolution. But now of course do I have to set things up again. Fist of all .What do I have to do?. Motor tuning and  double all the values in there?. There must be a easier way that I completely overlooked.
Re: Full Step to Microstepping
« Reply #1 on: July 05, 2007, 01:25:05 PM »
I would think the only change would be in motor tuning, steps per. Everything else should stay the same unless you have to up your pulse rate to get the speed you need.
« Reply #2 on: July 05, 2007, 02:56:26 PM »
Do you recommend separate profile one with FullStep one with HalfStep , EightStep & MicroStep ?
« Reply #3 on: July 05, 2007, 03:35:09 PM »
If you have the need to switch back and forth, it would be a good idea to have seperate profiles.
« Reply #4 on: July 05, 2007, 06:23:30 PM »
Thanks ,
I just did ... let me tell you figuring out the right steps took me some time there. Is eightStep also called microstepp ? Or the whole terminology is Microstepping ?
