Hello Guest it is October 20, 2026, 02:51:50 PM
Author Topic: G16 Polar moves in X-Z plane or limited to x-y plane only?  (Read 7341 times)
« on: December 18, 2017, 07:20:17 PM »
Are G16 polar moves limited to the x-y plane?
If they are limited to the x-y plane then I will use FORMULAS instead
Thanks in advance.
Offline rcaffin
  •  1,073 1,073
Re: G16 Polar moves in X-Z plane or limited to x-y plane only?
« Reply #1 on: December 19, 2017, 03:48:20 AM »
Read the manual.
Mach3Mill_1.84.pdf
Page 10-19
Section 10.7.7
"It is possible for G0 and G1 moves in the X/Y plane only to specify coordinates as a radius
and angle relative to a temporary center point."
Good luck with formulas. I found some limitations ...
Roger
