Hello Guest it is October 20, 2026, 02:50:40 PM
Author Topic: Cutting points instead of line  (Read 8708 times)
« on: December 13, 2017, 12:43:20 PM »
Hello,
I have a plasma CNC and I'm trying to cut a simple path (a square), the problem is that the CNC is cutting points instead of a line.
I'm new using Mach3 but I think that it might be a software configuration problem because in the drawing I see the cut path as a line, the machine follows the path but instead of cutting a line it only makes points.
Link to a picture of the points.
https://imgur.com/8jbI11w
Re: Cutting points instead of line
« Reply #1 on: December 13, 2017, 03:27:08 PM »
it rather looks like either your plasma is not able to run continously or your machine is inertrupting the cut signal.
Can you put a voltmeter on the cut signal to determine whether its your machine or your plasma.
« Reply #2 on: December 30, 2017, 02:07:37 AM »
Could you post the Gcode just to make sure that it is correct?
Mike
