Mach Discussion => General Mach Discussion => Topic started by: Tona on December 13, 2017, 01:43:20 PM
Hello,
I have a plasma CNC and I'm trying to cut a simple path (a square), the problem is that the CNC is cutting points instead of a line.
I'm new using Mach3 but I think that it might be a software configuration problem because in the drawing I see the cut path as a line, the machine follows the path but instead of cutting a line it only makes points.
(https://imgur.com/8jbI11w)
Link to a picture of the points.
https://imgur.com/8jbI11w (https://imgur.com/8jbI11w)
it rather looks like either your plasma is not able to run continously or your machine is inertrupting the cut signal.
Can you put a voltmeter on the cut signal to determine whether its your machine or your plasma.
Could you post the Gcode just to make sure that it is correct?
Mike
