Hello
Guest
it is
October 20, 2026, 09:31:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
windows 10 pro and mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: windows 10 pro and mach3 (Read 10001 times)
hmoore01
23
on:
December 09, 2017, 09:15:37 AM »
After searching this forum over and over I haven't found the definite answer.
I am thinking about upgrading my PC to a new one running windows 10
I am using a ESS and running fine on 64 bit windows
what kind of luck running windows 10 PRO with mach3 with an ESS
I have seen that it should work, but I wound love to hear from someone who has used windows 10 with an ESS 64 bit ETC.
Thanks in advance
Harry Moore
MadDogSTrack
25
Re: windows 10 pro and mach3
Reply #1 on:
December 09, 2017, 11:54:39 AM »
Hello Harry;
I have Win 10 Pro 64 bit/ ESS/ Mach 3 with a fairly low spec'd. computer.
It all works fine.
One thing to watch is automatic upgrades/ updates. Turn this off, or better yet, keep your Mach3 computer off of the 'net.
-MDog
hmoore01
23
Reply #2 on:
December 11, 2017, 06:52:10 AM »
It looks like I am going to do the upgrade on my pc
I plan on one of the dell mini
It is very small and easy to put in a cabinet
Again thanks for your response
Harry
ger21
6,295
Reply #3 on:
December 11, 2017, 10:07:39 AM »
If you were already running a 64 bit OS, then you shouldn't see any difference with Windows 10. The only thing is that you might want to defer updates. so it doesn't update while running a program.
hmoore01
23
Reply #4 on:
December 11, 2017, 10:12:19 AM »
Good thought.
I will make sure my system will stay off line
Harry
Print
Pages:
1
Go Up
« previous
next »
