Hello Guest it is November 13, 2026, 09:37:12 AM
Author Topic: Can't Get Spindle To Turn On  (Read 9212 times)
« on: November 30, 2017, 12:58:31 PM »
Hi, I'm Max and I am new to the Mach community. I see a lot of topics posted here about people not being able to get the spindle to work. I have read through about a million things about ports & pins and have tried thousands of different variations of port & pin configuration. I purchased my machine off of eBay; 6040z 4-Axis CNC engraver with a Yoocnc M3-USB-JB4 (V04) motion control card equipped. The Machine came with a version of Mach3 on a disc and later found out that is was pirated. So I went and purchased a clean version of the software hoping that would magically solve my spindle issue, but unfortunately I am still stuck in the same mud pit. Anyway, I'm hoping that someone can help me out here so I can start making chips.  :'(
Attached is a copy of my XML file.
Thanks in advanced
Re: Can't Get Spindle To Turn On
« Reply #1 on: November 30, 2017, 06:10:22 PM »
Perhaps sharing some information on motor type and driver would help others figure out how to help you.  For example, does it use a VFD to drive the spindle ?
« Reply #2 on: November 30, 2017, 06:12:50 PM »
Yes. Nowforever VFD. I'm currently at work so if you're looking for my current VFD settings then I can share them later when I get home.
