Hello Guest it is November 22, 2026, 02:46:23 PM
Author Topic: Cirkles in Mach 3 Problem  (Read 22251 times)
  •  9,378 9,378
Re: Cirkles in Mach 3 Problem
« Reply #10 on: November 20, 2017, 04:02:18 AM »
Something else you should try is changing the toolpath to anti-clockwise as that will change the direction of loading on the lead-screws and may improve the backlash comp. performance. But overall nothing beats reducing the actual, mechanical, backlash.
« Reply #11 on: November 20, 2017, 05:34:38 AM »
tried that already.. same result.
looks like i have to disassamble and work on the nuts to eliminate/reduce backlash...
Thanks alot!
