Hello Guest it is November 22, 2026, 01:38:11 PM
Author Topic: Stop CV on Angles?  (Read 8039 times)
Stop CV on Angles?
« on: October 30, 2017, 03:19:19 PM »
Does Mach4 have anything similar to Stop CV On Angles like Mach3 had?
Re: Stop CV on Angles?
« Reply #1 on: October 30, 2017, 10:03:16 PM »
Well, you can set the feed rate for any angle from 0 - 179 degrees. So, setting the speed for angles above 90 degrees to 0 would work.
The mcCVTuning wizard can populate the table for you giving the same result.
But, the mcCVTuningWizardV3 wizard in this topic is far better. It's smart enough to set the feed rate for angles to maintain a tolerance you enter in the wizard.
http://www.machsupport.com/forum/index.php/topic,35860.msg245507.html#msg245507
« Last Edit: October 30, 2017, 10:05:59 PM by Chaoticone »
« Reply #2 on: October 31, 2017, 08:06:06 PM »
Your CVTuningWizard is awesome.  That should do the trick.  Thanks.
« Reply #3 on: November 01, 2017, 08:01:49 AM »
No problem
