Hello Guest it is November 03, 2026, 02:51:09 AM
Author Topic: input signal hotkey & Win 64  (Read 10436 times)
« on: October 26, 2017, 03:53:38 PM »
Hello
I falls on almost the same problem that on this post.
http://www.machsupport.com/forum/index.php/topic,24815.msg175556.html#msg175556
I use my "home PC" (with no CNC connected) to work on scripts, and I use hotkeys to simulate the inputs (Probe, Homing, etc).
Until now, it worked perfectly on XP pro 32 bits, but I changed for a Win 7 - 64 bits, and now, I can no longer simulate the inputs with the keyboard keys.  I assume it's because no parallel port is installed ? (and can't be installed on a 64 bits system)
Does anyone know a workaround to get the hotkey working on a 64 bit system ? (It is only used to develop)
Mach3 3.043.062 - Win 7 - 64 Ultimate
thanks
David
Re: input signal hotkey & Win 64
« Reply #1 on: October 27, 2017, 03:47:06 PM »
I have Mach3 on my laptop, Windows 8 64 bit and I can assign a hotkey just fine.
In the pics attached I assigned Input#1 as enabled, emulated and emulated with lower case a. After restarting Mach on the diagnostics screen Input#1 LED operates
on <a> as expected.
I note from the link you posted that it would fail with a real time signal like Probe, haven't tried it yet.
« Reply #2 on: October 27, 2017, 03:57:03 PM »
just tried the same trick with the Probe input. You can enable it, emulate it and assign a hotkey and it duly activates the Digitize LED on the Diagnostics
screen.
When I MDI a long slow G31 command hitting the hotkey does not stop the movement. Clearly my laptop has no active motion controller and a Probe signal
is meant to activate a response within the motion controller, ergo no action. This was the conclusion of the other thread.
« Reply #3 on: October 27, 2017, 04:31:11 PM »
Hello
Thanks for testing
Yes same for me, the LED works but G31 and homing do not works .. so until I found another way, I will continue to develop on my old PC with XP pro 32 an pulse engine installed (// driver)
David
