Hello Guest it is November 13, 2026, 03:02:30 PM
Author Topic: Can not seem to carve out a simple box ?  (Read 49959 times)
Re: Can not seem to carve out a simple box ?
« Reply #30 on: October 02, 2017, 01:14:26 PM »
It is working !!!!  but now moves super duper slow....8 move 6....2 moves 2.....4 moves 4 etc
« Reply #31 on: October 02, 2017, 01:49:56 PM »
OK   Figured out the Speed thing.....Now....The Z Axis Moves UP to Engrave...Down...to Move...Its Backwards....
« Reply #32 on: October 02, 2017, 02:51:49 PM »
on the Z Dir pin check active low or uncheck it if already checked.
« Reply #33 on: October 02, 2017, 03:05:03 PM »
When I Do That...Z Wants to Drill to the Bottom of the Table the Unit Stands on...It was Checked....Un Checked it and it was drilling to China....Pun Intended :)
« Reply #34 on: October 02, 2017, 03:15:16 PM »
not quite sure whats going on, but its going in the right direction?
« Reply #35 on: October 02, 2017, 03:19:43 PM »
When I UnCheck Z Dir Pin...Page up Moves Z Down...Page Down moves Z UP...When It Zero's it wants to Drill below the actual ZERO mark...A LOT........What I Do Notice is this....X +0.000......Y+0.000    Z-0.000....Z Shows A Negative
« Reply #36 on: October 02, 2017, 03:22:36 PM »
I think your Z0 is way out. Usually machine Z0 is the very top of travel. Work Z0 is the surface of the work.
Do you have home switches and are they configured?
« Reply #37 on: October 02, 2017, 03:51:41 PM »
I reset The Machine "Home"...zeroed.....What happens now is that ....I hit the STOP button...and the Z Goes below the Zero Mark Setting.....So Close......Everything is how it should be except the Z... My Motor Settings are Where they should Be....X and Y Behave Perfectly...... But Not The Z
« Reply #38 on: October 02, 2017, 03:59:37 PM »
one possibility to check is that the stepper driver has the right microstepping setup.
Could you change say the X and Z motor wires over just to check?
« Reply #39 on: October 03, 2017, 05:09:04 AM »
I don't think I can...Maybe Swap the pin Numbers ???
