Hello Guest it is November 22, 2026, 02:08:09 PM
Author Topic: Can not seem to carve out a simple box ?  (Read 50145 times)
Re: Can not seem to carve out a simple box ?
« Reply #40 on: October 03, 2017, 08:03:45 AM »
I know I have said this before, But I am Such an Idiot...Problem was coding from LazyCam..It work Perfectly and I am not going to TOUCH ANYTHING ! ! ! !     Thank you Tweakie.CNC and Joeaverage for all your help....Like I stated before...So used to the Dahlgren and Engravelab....Now all I need to do is Make a Vacuum Attachment :)  THANK YOU THANK YOU THANK YOU ! ! ! !
« Reply #41 on: October 03, 2017, 09:32:27 AM »
New Wrinkle...When I Set the Cut Depth in Lazy Cam...Could be .12   or 1,500,000.00...It does not drop below actual Z zero...
« Reply #42 on: October 03, 2017, 09:47:37 AM »
I Just did a Table Offset of .12...Seem to do the trick for now
  •  9,378 9,378
« Reply #43 on: October 03, 2017, 10:36:41 AM »
Excellent news, I am pleased that you have it sorted.  :)
