Hello Guest it is November 13, 2026, 11:34:41 AM
Author Topic: Z Depth ??'s  (Read 11136 times)
Z Depth ??'s
« on: September 21, 2017, 12:20:42 PM »
Hi...Newbie (Still)...I have tried setting the Z Depth but does not event touch .....I am using a 3/16 thick piece of brass to set my "0"....
I go in to the material thickness....Set that to .1875......Nada....I am perplexed ....x and y go where they are supposed to...but not the z
Billy
Re: Z Depth ??'s
« Reply #1 on: September 21, 2017, 04:31:34 PM »
You need to jog the tool down to the surface of your part, then zero the Z axis there.
Re: Z Depth ??'s
« Reply #2 on: September 22, 2017, 05:24:22 AM »
I have done that as well..........I have also set the z depth in lazy cam as to how deep to cut...I Updated the software...It has to be something simple I am just missing.......
Thank you for the reply
Re: Z Depth ??'s
« Reply #3 on: September 22, 2017, 05:32:12 AM »
what direction have you got your Z axis set for.
I follow the usual standard where Z=0 is the top of the material z=-1 is 1mm below the surface and Z=-10 is a humungous 10mm cut and it had better be soft
or something is going to break and Z=20 is 20mm above the material and out of harms way.
Re: Z Depth ??'s
« Reply #4 on: September 22, 2017, 06:03:08 AM »
I got it, lets just say....I'm an idiot...ughhhh...Proper Depth setting....We have a Dahlgren 2516
I am so used to that...we got a CNC to take off some of the load....
Right Now I Just Need it to engrave nameplates and brass dies....one step at a time
Thank you all for your help ! ! ! !
