Hello Guest it is November 13, 2026, 02:53:31 PM
Author Topic: Single Line Cut for Plates  (Read 9309 times)
« on: September 19, 2017, 09:23:40 AM »
Hi...Trying to figure out if there is a way to have engraver only make one cut...like a single line font...Cut each letter only once...not each side of the letter...Hope I am Making Sense.... On our Dahlgren...If we use a single line font...it only makes one stroke/pass...like down the middle...
not ...The left side if the "I"...The Right Side of the "I"....ect
Billy
Re: Single Line Cut for Plates
« Reply #1 on: September 19, 2017, 03:44:42 PM »
If the font you are using is a standard Windows font it is an outline font and will get cut twice as you see. You need a single stroke font. You can find 10 of them for download on the CamBam website. You might give CamBam a try as it is quite nice too.
« Reply #2 on: September 19, 2017, 03:46:49 PM »
Thank you. ! ! ! !...So used to Engravelab
  •  9,377 9,377
« Reply #3 on: September 20, 2017, 01:00:19 AM »
It may also be worth while taking a look at F-Engrave http://scorchworks.com/Fengrave/fengrave.html (it is free to use).
« Reply #4 on: September 20, 2017, 10:25:12 AM »
The "Mono TXT" font in the Write wizard included with Mach3 does a pretty good job as well, (if you have a few aspirin handy)   :)
But, thanks to Tweakie (and Scortch), I'm a long time user of F-Engrave, its fantastic !
RC
