Hello
Guest
it is
November 13, 2026, 02:52:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Jogging Issue when switching from Inches to mm
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Jogging Issue when switching from Inches to mm (Read 11802 times)
Cerk
4
on:
August 27, 2017, 06:47:43 AM »
Hi Everyone,
Recently received a new CNC from Velox. It came setup for imperial but we use metric in my workshop. Have reset the profile for mm and recalculated the steps/velocity etc. The issue I have is that when I jog the machine it moves .00025-.00051-.0076-.00102 etc . Instead of increments of .00025. I'm assuming that it's moving in percentage increments of 1"(25.4mm). Can't seem to find anything in the manual to correct this? Does ayone know how to fix this?
Charles
Logged
Tweakie.CNC
9,377
Super Kitty
Re: Jogging Issue when switching from Inches to mm
Reply #1 on:
August 27, 2017, 07:03:28 AM »
Mach3 only saves it's settings on close.
Once Mach3 has been shutdown correctly everything should be good on the next restart.
Logged
Cerk
4
Reply #2 on:
August 27, 2017, 07:16:54 AM »
Thanks Tweakie,
Have saved and restarted the machine. Problem is still there.
Logged
ger21
6,295
Reply #3 on:
August 27, 2017, 07:55:37 AM »
If you jog much farther, does it continue to get further out, or does it come back? My guess is your seeing a rounding error, based on your steps/unit setting. It shouldn't accumulate over long distances.
Logged
Cerk
4
Reply #4 on:
August 27, 2017, 05:21:06 PM »
Hi Gerry,
It moves to the nearest number that is a percentage of 1"(25.4mm) i.e if I want to move 1mm then it will move to 1.0008 .
Logged
Cerk
4
Reply #5 on:
August 27, 2017, 06:57:45 PM »
Might have found the issue. My Older machine (K23925) has metric 5mm pitch screws where as this new velox machine has imperial 8TPI screws. Does this mean that it will always have to round off the position to the nearest metric point?
Logged
Print
Pages:
1
Go Up
« previous
next »
