Hello Guest it is November 22, 2026, 02:45:09 PM
Author Topic: Triple edge zero finding plate problems  (Read 27746 times)
« on: July 31, 2017, 10:11:21 AM »
Hi, I recently found a Mach3 script by Allen Massey for an edge finding plate.
I downloaded the script to the hidden Auto zero file and wired up the breakout board as described. I activated the probe in ports and pins and began the testing. On the diagnosis page the digitise LED failed to light when I touched the probe to ground. As far as I understand I take a wire from my port (port 13, the only port free) to the probe and a second wire from the ground pin on the same  pin 13 to the edge finder. Touching the two together should cause the LED to light. Any ideas?
Secondly I note that the script I have received is in inches whereas my machine is set to millimetres. I presume that all inch references will have to be converted to metric. I am not familiar with Mach 3 code and I wondered if there is anyone out there who is familiar with the Allen Massey script who could advise me which parts of the script need to be altered.
regards Ian
  •  9,378 9,378
Re: Triple edge zero finding plate problems
« Reply #1 on: August 01, 2017, 12:38:44 AM »
Hi Ian,
Check that you have Enabled and set Probe to Active Low and also the Port and Pin (13) correctly.
« Reply #2 on: August 01, 2017, 03:22:25 AM »
Yes done that already. thanks
  •  9,378 9,378
« Reply #3 on: August 01, 2017, 03:37:22 AM »
Hi Ian,
Assuming you have set / configured Pin13 correctly then temporarily connecting it to GND should activate the Digitize LED on the Diagnostics (Alt-7) page. Does it do this ?
« Reply #4 on: August 01, 2017, 03:49:38 AM »
No, nothing happens when I ground the pin.
  •  9,378 9,378
« Reply #5 on: August 01, 2017, 04:37:51 AM »
If you attach your .xml file ( <your profile> .xml from your Mach3 folder) I will check your configuration. Copy it and rename the copy to iparr.xml then use the Additional Options to attach.
Connect a voltmeter between Pin 13 and GND. What is the voltage reading ?
Connect the voltmeter between Pin 13 and +5 Volts. What is the reading ?
« Reply #6 on: August 01, 2017, 07:36:09 AM »
Hi thanks for your patience,
Pin 13 to GND = 4.8v
Pin 13 to +5v = 0.25v
Hope this helps, Ive attached what I hope is the profile folder.
Thanks again.
Ian
  •  9,378 9,378
« Reply #7 on: August 02, 2017, 12:15:09 AM »
Hi Ian,
Unfortunately your .xml file did not attach.
The following pic shows how you should be configuring pin 13 for operation with your touch plate.
« Reply #8 on: August 02, 2017, 08:44:34 AM »
Thans for the reply
Yes that is exactly how I have enabled pin 13. I've checked it several times.
How did the voltage readings check out? Could it be a faulty board? I had a previous board with a faulty Estop input.
I've tried to send the file again, but I get an error message. Can I email the file directly to you?
regards
Ian
  •  9,378 9,378
« Reply #9 on: August 02, 2017, 09:41:58 AM »
Hi Ian,
The voltage readings are correct.
A question I should have perhaps asked before - What make and model of breakout board are you using (a picture may be good) ?
(e-mail me your .xml file, my mail box address is under my avatar)
