Hello Guest it is October 23, 2026, 12:35:40 AM
Author Topic: Mach 4 brains  (Read 10143 times)
Offline N4NV
  •  398 398
Mach 4 brains
« on: July 02, 2017, 07:26:45 AM »
As I understand it there are no brains in Mach 4.  I am using Mach 3 and use a brain to communicate with a Cubloc PLC through the serial port to do a tool change on my lathe.  How can I do that in Mach 4?
Vince
Re: Mach 4 brains
« Reply #1 on: July 02, 2017, 05:19:07 PM »
latest builds of Mach4 have PLC funtionality. Check recent threads...there is at least one of interest.
Re: Mach 4 brains
« Reply #2 on: July 02, 2017, 05:37:33 PM »
Configure > PMC
Offline N4NV
  •  398 398
Re: Mach 4 brains
« Reply #3 on: July 02, 2017, 09:32:11 PM »
Configure > PMC
Cool, i'll look through the manual to see how to implement it.  It would be nice if I can get rid of the cubloc.
Vince
Offline N4NV
  •  398 398
Re: Mach 4 brains
« Reply #4 on: July 02, 2017, 09:38:06 PM »
I just searched the latest Mach 4 manual and no hits for PMC.  Is there documentation somewhere else?
Vince
Re: Mach 4 brains
« Reply #5 on: July 02, 2017, 10:29:10 PM »
Look in your C:\Mach4Hobby\DOCS folder and double click on the PmcEditor.chm file.
You may not see the .chm file name extension, depending on your OS and configuration.
If you installed Mach4Hobby in other than the default location, adjust where you look
accordingly.
If you have Mach4 running, you can click on Help > Documentation Folder
Steve Stallings
www.PMDX.com
Steve Stallings
www.PMDX.com
Offline N4NV
  •  398 398
Re: Mach 4 brains
« Reply #6 on: July 03, 2017, 07:10:19 AM »
Found it, thanks!
Vince
