Hello Guest it is November 01, 2026, 10:12:25 AM
Author Topic: lazy cam help  (Read 11337 times)
lazy cam help
« on: June 22, 2007, 05:50:30 PM »
I cant get lazy cam pro to load this file can someone try for me
lazy cam 2.02
Thanks Andrew
Re: lazy cam help
« Reply #1 on: June 22, 2007, 08:12:28 PM »
It loaded fine for me. I'm using version 2.076 pro version.
Re: lazy cam help
« Reply #2 on: June 22, 2007, 10:10:36 PM »
Also loaded fine using Lazy Cam 2.05.
Bob @ BobsShop
Re: lazy cam help
« Reply #3 on: June 22, 2007, 10:25:56 PM »
Andrew, attached is a similar spacer that I drew recently with CADX11 and imported into LCAM.  Interesting to note, that I have four entities around the outside edge - when I loaded your file into LCAM the outside contained 257 entities - that was after cleaning and optimizing.  My drawing is only 2" X 4" though.
Since I was able to load your file the number of entities should not have caused a problem for you, but the complexity did raise some questions.
Bob @ BobsShop
Re: lazy cam help
« Reply #4 on: June 23, 2007, 03:39:31 AM »
thanks guys changing lazycam version solved problem
Andrew
