Hello Guest it is November 13, 2026, 08:07:00 PM
Author Topic: Install Problem  (Read 8239 times)
Install Problem
« on: May 18, 2017, 03:31:40 PM »
I installed Mach3 on my laptop with parallel adapter. It did the parallel port check O.K. When I load the program, the reset flashes and it will not stop when clicked on. It has a message saying External EStop Required. What do I need to do to reset the program?
  •  9,377 9,377
Re: Install Problem
« Reply #1 on: May 19, 2017, 12:22:57 AM »
Changing the Active state of the Estop in Ports & Pins / Input Signals should do it.
It should be pointed out that because of the various and many problems associated with laptops using a parallel port this method of operation is not supported by Artsoft. You should be using an external motion controller (such as the ESS, etc.) with your laptop.
Re: Install Problem
« Reply #2 on: May 19, 2017, 12:34:18 AM »
Thank you. That did it.
