Hello Guest it is October 20, 2026, 04:07:40 PM
Author Topic: Touch Off Plate - DIY Depth Sensor ?  (Read 12146 times)
deleteallusers
« on: June 20, 2007, 10:50:25 PM »
Hello,
I have a DIY CNC machine running mach3.
I’m new to mach3 and to CNC machines; I’m trying to mill a PCB.
I’m using a 0.015 stub end mill 2 flute
I’m having depth problems, I always cut to deep or two shallow.
I need to cut Z-0.0075  down from Z0 (Z0 = the end mill just touching the top
of the material).
My problem is that I’m breaking my end mills because I can’t set them correctly
down on the material. (I level my work area via 4 screws at the corners)
Should I build and use a touch off plate ? I don’t know what to use.
I’ve heard about some kind of spring loaded depth guard that presses on the material each plunge. Is there a web link, How do I ?
I’m also thinking about adding a DIY vacuum modification.
QUESTION:
Is there anything I can build that will provide realtime feedback of the current depth
so the program can make sure it’s always at Z–0.0075 ?
What other DIY solutions can I use ? I don’t want to spend $$$ on ready made solutions.
What about a pressure sensor ? That way I could do somthing like this ...
   if ( getEndMillPSI ( Spindle_POS ( Z ) ) >= dec_to_PSI ( 0.0020 ) )
         set_drill_depth(Z-0.0075);
     }else{
         JOG ( Z, ( Spindle_POS ( Z ) - 0.0001 ) );
HOW can I build a DIY pressure sensor ?
« Last Edit: June 20, 2007, 11:04:06 PM by deleteallusers »
Offline Greolt
  •  956 956
Re: Touch Off Plate - DIY Depth Sensor ?
« Reply #1 on: June 20, 2007, 11:35:19 PM »
Deleteallusers
There has been a lot of posts about "Touch Off Plates"   That's how I learned about them.
If you follow this link it will take you to a thread I started on CNCzone and explains my method.
It may or may not be what you're looking for.
Can't help with a "spring loaded depth guard"
http://www.cnczone.com/forums/showthread.php?t=36099
Also regarding a vacuum hold-down that would be suitable for PCBs take a look at this one.
http://www.cnczone.com/forums/showthread.php?t=34537
I have not used mine for PCBs but I'm sure it would be good and it might give you some ideas.
Greg
