Hello Guest it is October 18, 2026, 10:32:29 PM
Author Topic: Limit switch set up on Mach3 with the Gecko g540  (Read 61325 times)
Offline TPS
  •  2,627 2,627
Re: Limit switch set up on Mach3 with the Gecko g540
« Reply #40 on: March 08, 2018, 02:39:47 PM »
i would use "ENABLE 1"  instead of "CHARGE PUMP".
i never understood "CHARGE PUMP", maybe depending of my bad english.
sorry i will finish for today, allready late here in Bavaria.
but i think we are very Close.
« Last Edit: March 08, 2018, 02:47:49 PM by TPS »
« Reply #41 on: March 08, 2018, 02:55:40 PM »
Thank you again for the help.
I used my o-scope to test the output of pin 16 (charge pump) to pin 25 (gnd) at the db25 of the UC100. I can cycle reset and see the signal change state. If I plug the gender changer into the UC100 and check pin 16 I get no change of state. Within the gender changer is where the charge pump signal stops. Off to the local electronics store for a new one.
« Reply #42 on: March 08, 2018, 04:45:17 PM »
I bought two new gender changers for less than $5. I installed one and this seems to work. All was functional except the charge pump until I changed another setting. In CONFIG--> GENERAL CONFIG, I ticked the box for "Charge Pump On In Estop". I tested this out and the motors go inactive if I close Mach3. This is what I was looking for. All limit and home switches behave exactly as expected. Thus I was finally able to set the machine to machine coordinate home.
Thanks again TPS, your insight was absolutely key to my success!!
...and I didn't have to tear everything down t figure this out.
Tony
Offline TPS
  •  2,627 2,627
« Reply #43 on: March 09, 2018, 08:39:58 AM »
Hello Tony,
glad to hear that everthing is ok now.
i am happy that i was able to set a few Triggers for the drirection to go.
Thomas
