Hello Guest it is November 22, 2026, 09:27:42 AM
Author Topic: Z Axis freefloat height problem  (Read 9621 times)
« on: April 22, 2017, 04:34:12 PM »
hi! so i have a problem i believe is with my post processor. i have a free float head with only 1 switch for the probe and it is working perfect....here is what happens. i get x and y zeroed out where i want...no problems with them it is only the z axis.....z goes and finds zero with the probe, then it zooms up around an inch and sets zero with a g92 ...then it raises the tool height of 0.06 and reads this on the dro but in settings the g92 collum has numbers.....so all in all i cant cut anything with the torch 1+" above the material. Ive went through sheetcam and mach3 numerous times Im so frusterated, anyways anyhelp is much apreaciated
here is my pp:
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("plasma AVHC10 post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
ctrl:AppendText("Designed for use with Mach3 and PriceCNC AVHC10\n")
ctrl:AppendText("Post variables:\n")
ctrl:AppendText("refdistance - set the distance between each reference\n")
end
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/05
-- Added new arc handling
-- created 27/10/04
-- Based on plasma1.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G53 G90 G40\n F1\n S500\n")
switchoffset = 0.7
bigarcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
post.Text (" M05 M30\n")
end
function OnRapid()
if(math.hypot(endX-currentX , endY-currentY) < 0.001 and endZ < currentZ) then return end
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.Eol()
end
function OnPenDown()
post.ModalText(" G31 Z -100")
post.ModalNumber (" F", 500 * scale, "0.0###")
post.Eol()
post.ModalText(" G92 Z0.0\n")
post.ModalNumber(" Z", switchoffset, "0.0000")
post.Eol()
post.CancelModalNumbers()
post.ModalNumber (" Z", pierceHeight * scale, "0.0000")
post.Eol()
post.Text ("\n M03\n")
end
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Text (" G04 P")
post.Number (endDelay,"0.###")
post.Eol()
end
end
function OnNewOperation()
post.Text (" (Process: ", operationName, ")\n")
end
function OnComment()
post.Text(" (",commentText,")\n")
end
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.Text (" (", toolName, ")\n")
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
Re: Z Axis freefloat height problem
« Reply #1 on: April 22, 2017, 04:35:43 PM »
zeroed out ready to cut
« Reply #2 on: April 22, 2017, 04:37:41 PM »
somehow now there is g92 spacing between material and what the gcode thinks is zero.....it then goes up the 0.06" for the torch height
« Reply #3 on: April 22, 2017, 04:39:33 PM »
hahahaha :( ....ugh ya right its not gonna cut an inch above material.......it times out the start arc......i have no idea whats wrong
