Mach Discussion => General Mach Discussion => Topic started by: cohippy on April 22, 2017, 05:34:12 PM
hi! so i have a problem i believe is with my post processor. i have a free float head with only 1 switch for the probe and it is working perfect....here is what happens. i get x and y zeroed out where i want...no problems with them it is only the z axis.....z goes and finds zero with the probe, then it zooms up around an inch and sets zero with a g92 ...then it raises the tool height of 0.06 and reads this on the dro but in settings the g92 collum has numbers.....so all in all i cant cut anything with the torch 1+" above the material. Ive went through sheetcam and mach3 numerous times Im so frusterated, anyways anyhelp is much apreaciated
here is my pp:
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("plasma AVHC10 post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Modal G-codes and coordinates\n")
ctrl:AppendText("Comments enclosed with ( and )\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
ctrl:AppendText("Designed for use with Mach3 and PriceCNC AVHC10\n")
ctrl:AppendText("Post variables:\n")
ctrl:AppendText("refdistance - set the distance between each reference\n")
end
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/05
-- Added new arc handling
-- created 27/10/04
-- Based on plasma1.post
function OnInit()
post.SetCommentChars ("()", "[]") --make sure ( and ) characters do not appear in system text
post.Text (" (Filename: ", fileName, ")\n")
post.Text (" (Post processor: ", postName, ")\n")
post.Text (" (Date: ", date, ")\n")
if(scale == metric) then
post.Text (" G21 (Units: Metric)\n") --metric mode
else
post.Text (" G20 (Units: Inches)\n") --inch mode
end
post.Text (" G53 G90 G40\n F1\n S500\n")
switchoffset = 0.7
bigarcs = 1 --stitch arc segments together
minArcSize = 0.05 --arcs smaller than this are converted to moves
end
function OnNewLine()
post.Text ("N")
post.Number (lineNumber, "0000")
lineNumber = lineNumber + 10
end
function OnFinish()
post.Text (" M05 M30\n")
end
function OnRapid()
if(math.hypot(endX-currentX , endY-currentY) < 0.001 and endZ < currentZ) then return end
post.ModalText (" G00")
post.ModalNumber (" X", endX * scale, "0.0000")
post.ModalNumber (" Y", endY * scale, "0.0000")
post.ModalNumber (" Z", endZ * scale, "0.0000")
post.Eol()
end
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.0###")
post.Eol()
end
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
end
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Number ((arcCentreX - currentX) * scale, "0.0000")
post.Text (" J")
post.Number ((arcCentreY - currentY) * scale, "0.0000")
post.Eol()
end
function OnPenDown()
post.ModalText(" G31 Z -100")
post.ModalNumber (" F", 500 * scale, "0.0###")
post.Eol()
post.ModalText(" G92 Z0.0\n")
post.ModalNumber(" Z", switchoffset, "0.0000")
post.Eol()
post.CancelModalNumbers()
post.ModalNumber (" Z", pierceHeight * scale, "0.0000")
post.Eol()
post.Text ("\n M03\n")
end
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Text (" G04 P")
post.Number (endDelay,"0.###")
post.Eol()
end
end
function OnNewOperation()
post.Text (" (Process: ", operationName, ")\n")
end
function OnComment()
post.Text(" (",commentText,")\n")
end
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.Text (" (", toolName, ")\n")
end
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
end
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
end
zeroed out ready to cut
somehow now there is g92 spacing between material and what the gcode thinks is zero.....it then goes up the 0.06" for the torch height
hahahaha :( ....ugh ya right its not gonna cut an inch above material.......it times out the start arc......i have no idea whats wrong
