Hello Guest it is November 22, 2026, 09:57:18 AM
Author Topic: Estop  (Read 8318 times)
Estop
« on: April 18, 2017, 11:59:42 AM »
I'm new to Mach3 my issue is this when I turn my controller on and I'm in mach 3 screen the reset is flashing my steppers are locked when I reset the steppers disengage  it seems to work in reverse what did I miss Thanks for your help.
  •  9,378 9,378
Re: Estop
« Reply #1 on: April 19, 2017, 12:57:24 AM »
Try changing the Active state of the Enable pins that are used (Config. / Ports & Pins / Output Signals).
« Last Edit: April 19, 2017, 04:24:49 AM by Tweakie.CNC »
