Hello Guest it is October 20, 2026, 03:58:34 PM
Author Topic: Lazycam/ Cams  (Read 8732 times)
Lazycam/ Cams
« on: April 17, 2017, 03:43:59 PM »
Hi folks,
A little off subject.
I need to drill 360,000 holes in a 13"x180" flat sheet metal part.
Lazycam does about 1/200th of this and any more freezes up the PC.
I use Lazycam for most everything so
I'm not sure of other CAMs.
Any suggestions would be appreciated.
  •  9,374 9,374
Re: Lazycam/ Cams
« Reply #1 on: April 18, 2017, 01:30:50 AM »
I am sure everyone has their own preferences but check out the Vectric range of CAD/CAM software http://www.vectric.com/
Re: Lazycam/ Cams
« Reply #2 on: April 18, 2017, 05:10:01 AM »
That's a lot of holes to be drilled.
Maybe consider breaking up the program into a smaller repeatable program that would be reliable.
Re: Lazycam/ Cams
« Reply #3 on: April 18, 2017, 12:36:22 PM »
This is one of those cases where a little hand codng may make more sense, and possibly incremental mode too. Use a subroutine for a row of holes done incrementally on the Y axis, increment the X axis incrementally and repeat the sub as many times as needed.
