Hello Guest it is September 08, 2026, 05:37:17 PM
Author Topic: Knee Mill Mach3 On Screen Calculator  (Read 27913 times)
« on: April 14, 2017, 09:45:47 PM »
I am trying to build a basic calculator on a manual mill "3 Axis Digital Readout" screenset. The calculator is built (buttons and DRO) And I understand how to write the VB script to the buttons, but I don't see how the DRO will work or how to Identify it in my script.
Any help will be greatly appreciated,
Max ?
Re: Knee Mill Mach3 On Screen Calculator
« Reply #1 on: October 12, 2017, 03:11:42 PM »
Hi Max,
have a look at my samples, one of them is just doing what you want to do.
Download: http://www.kd-dietz.com/klausphp/index_eng.html
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: October 30, 2017, 04:52:41 AM »
Thanks Klause,
The calculator is very nice! I have a screenset that I want to use with a calculator that is built in to the screen that I use for a digital read out when the mill is being used in manual mode. I would like the calculator to be part of that screen and not a pop up window. Do you know how to do this?
Max
« Reply #3 on: October 30, 2017, 05:39:23 PM »
Hi Max
the keyboard sample isn't a popup window, it's a screenset page . Just put the keyboard part of the sample to your screenset page and adapt it to your needs.
Klaus
Offline TPS
  •  2,627 2,627
« Reply #4 on: December 22, 2017, 12:32:55 PM »
Hello Max,
if you can post your Screen, maybe we can get some more ideas what you are trying to do.
for the moment i am no able ,maybe depending on my bad english, what you are trying
to do.
Regards Thomas
« Reply #5 on: May 21, 2019, 08:35:34 PM »
Guys,
My screenset is attached, I did not know how to attach the Bitmap folder so some of the bitmaps may not show up. If you look at the screen labeled DRO, or screen 8, you will see what I am trying to do. Make an on screen calculator.
Any help would be appreciated.
Max
Offline TPS
  •  2,627 2,627
« Reply #6 on: May 22, 2019, 02:49:33 AM »
here is my quick and dirty solution, not realy tested for all cases, but i think you can get the idea
« Reply #7 on: May 22, 2019, 06:08:25 PM »
TPS,
That is great! It works! I have made no progress on this
Thank you!
Max 8)
