Hello
Guest
it is
November 13, 2026, 11:31:07 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Rapid feed
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Rapid feed (Read 9268 times)
CNCDK
23
Rapid feed
on:
April 07, 2017, 02:31:41 PM »
Is not it possible in an easy way to allow rapid traverse of 10% and keep g01 feed to 100%
kolias
1,165
Re: Rapid feed
Reply #1 on:
April 07, 2017, 03:20:03 PM »
Not clear what you ask but you can set the rapid speed and feed to different speeds. Your CAD program will set the rapid speed based on the tool you choose including the feed.
Nicolas
CNCDK
23
Re: Rapid feed
Reply #2 on:
April 07, 2017, 03:55:03 PM »
I want to run too rapid traverse of 10% and feed rate of 100%.
Is it possible ?? after I've run a test I run everything at 100%
Re: Rapid feed
Reply #3 on:
April 11, 2017, 07:15:04 AM »
CNCDK,
G0 command is rapid positioning at the max velocity defined in motor tuning.
G01 command is positioning at a feed rate defined by the user.
Use the correct command for what you want to do.
Print
Pages:
1
Go Up
« previous
next »
