Hello Guest it is November 12, 2026, 04:47:24 PM
Author Topic: Mach3 reads in cm and not in mm in Gcode file...  (Read 58310 times)
Re: Mach3 reads in cm and not in mm in Gcode file...
« Reply #10 on: March 12, 2018, 03:31:36 AM »
I will be re-calibrating either tonight or tomorrow and I will post the results.
Thanks for the advice!!!
« Reply #11 on: March 12, 2018, 05:00:30 AM »
or provide the correct and accurate data and calculate the correct answer...no guess work....no measuring...
« Reply #12 on: March 14, 2018, 04:30:28 AM »
Sorry for the delay in replying to everyone,
I ran the calibration cycle again repeatedly last night and found out where the fault was... ME!!! ::)
I was making a mistake between MM and CM, DOH!!!!  ::)
Once I got the Z working perfectly going up and down 10mm, (the safe height), whenever I ran a file to cut a 10mm square I realised that if one of three axis worked correctly I must have been doing something wrong.  So I started over again on the X and Y axis and got it right.  By the time I finished it was travelling 2000mm on the X axis repeatedly and 1000mm on the Y axis repeatedly.  :)
Before I had to replace the PC the X and Y 'steps per unit' was set to 710 now it is around 29.  I wanted to be accurate when I posted the new value so I went back to the machine to check and now every time I start MACH3 the machine crashes!!!! Not something one wants just before bed!!!  :(
I am running a 64Bit PC with 8GB RAM with Windows 7 (32bit) installed and as I said it was running fine for a few days...
The PC is not new but it was only used for about 3 months before I put it on my CNC machine last week...
There is always another problem isn't there? Any ideas please?
  •  9,377 9,377
« Reply #13 on: March 14, 2018, 04:59:03 AM »
Just an idea...
I would make a secure backup copy of my Mach3 folder.
Delete the existing Mach3 folder from drive C: then re-install Mach3 (version 0.62).
Copy my old <profile> .xml file from the backup to the new install. (if you have any special screens or macro's then copy them over as well).
« Reply #14 on: March 14, 2018, 06:10:09 AM »
Thanks Tweakie!
I will do it tonight and I will post the results.
« Reply #15 on: March 14, 2018, 03:59:25 PM »
Hello again,
Sadly that hasn't fixed the problem  :(  >:(
Do I need to do a complete reinstall of the PC?  It is odd that is was working fine for a few days and now it won't start MACH3...
Any suggestions please?  ???
  •  9,377 9,377
« Reply #16 on: March 15, 2018, 01:44:51 AM »
Sorry to hear that it didn't work.
I don't use win7 so can't really suggest anything other than Mach3 may need to be installed and run as Administrator and given the required privileges within any antivirus software etc.
« Reply #17 on: March 15, 2018, 04:00:21 AM »
Tweakie you running Windows XP then? With or without connecting to the internet?
I am very happy to install Win XP if that is going to solve this problem...
  •  9,377 9,377
« Reply #18 on: March 15, 2018, 04:27:52 AM »
Yes, I run WinXP but on a 32 bit PC and not connected to the net. I transfer all Gcode files (created using win10) with a memory stick.
« Reply #19 on: March 15, 2018, 04:46:23 AM »
Do you think that using a 32bit PC is important?
Shall I get an old DELL box then?
