Hello Guest it is November 22, 2026, 04:20:23 PM
Author Topic: Access to maintenance parameter values  (Read 12165 times)
« on: March 13, 2017, 09:10:08 AM »
Hi All
I want to get my lathe cnc lubrication system up and running
I would like to access some of the values contained in the maintenance flyout
Ideally I would like the combine the value of both the x Total Distance and Z Total Distance
when the combined value is greater than say 20 Metres bring on the pump for a few secs
using either brain or macro
I have noticed that GetParam("TotalHours") works but I can't see anything for Total Distance.
Any help would be greatly appreciated
George
Re: Access to maintenance parameter values
« Reply #1 on: March 15, 2017, 09:15:28 AM »
In the turn xml there are entries for dist0 to dist5, I assume those are axis xyzabc.  Mine have values for 0,2,3 which would correspond to x,z,a which I have.
There is also a SecondsOn value which I presume is what is retrieved with the TotalHours param.  I couldn't find anything else on the subject.
« Reply #2 on: March 16, 2017, 01:34:13 PM »
Hi rhtuttle
Many thanks for that. I have checked with my xml and they do indeed tie up with the values in my Maintenance statistics
Unfortunately I am still not able to access the info using these labels
When I was searching for past questions on the subject I noticed that back in 2006 there was a promise
that Art was going to establish the "calls" to allow this to happen. I am assuming this work did not go ahead.
Has all work on Mach3 now stopped or is this something that is still a possibility?
Cheers George
« Reply #3 on: March 16, 2017, 01:53:54 PM »
AFIK all work on M3 has stopped.  I would bet there is a list somewhere at NewFangled that includes all GetParam strings.  You might try posting a PM to Art Fennerty.  http://www.machsupport.com/forum/index.php/topic,27194.0.html
RT
« Reply #4 on: March 17, 2017, 09:43:52 AM »
Hi RT
Thinking about it, even if he did do that I am not using the latest version of Mach3 as I found the closer
I got to the final version the flakier the program stability became. I think there was just sticking plasters added
to patch up problems. Which was understandable I suppose as Mach 4 was now the focus to pay the bills.
I think I will just have to bite the bullet and rig up a sensor on one of the axis screws and deal with it that way.
It seems a great shame as I think the information I need is there (just out of reach) but just waiting to be tapped.
Many thanks for your help
George
« Reply #5 on: March 17, 2017, 09:48:35 AM »
start a support ticket and see what happens, worth a try.
