Hello Guest it is November 18, 2026, 12:37:02 PM
Author Topic: M6 macro in 4.2.0-3233  (Read 8312 times)
« on: March 03, 2017, 02:32:18 PM »
Hi
I recently updated from Mach4 4.2.0-2914 to 4.2.0-3233 and discovered that my manual tool change macro does no longer work.
The macro looks like this:
function m6()
    local selectedTool = mc.mcToolGetSelected(inst)
    local selectedToolDescription = string.format("%d: %s", selectedTool, mc.mcToolGetDesc(inst, selectedTool))
    local currentTool = mc.mcToolGetCurrent(inst)
    local currentToolDescription = string.format("%d: %s", currentTool, mc.mcToolGetDesc(inst, currentTool))
    if selectedTool == currentTool then
        mc.mcCntlSetLastError(inst, string.format("Current tool \"%s\" is selected tool, no change required", currentToolDescription))
    else
        mc.mcCntlSetLastError(inst, string.format("Please insert tool \"%s\" and hit cycle start", selectedToolDescription))
        mc.mcCntlToolChangeManual(inst, true)
        mc.mcToolSetCurrent(inst, selectedTool)
        mc.mcCntlGcodeExecuteWait(inst, string.format("G43 H%d", selectedTool))
    end
end
if (mc.mcInEditor == 1) then
    m6()
end
In Mach4 3233 this macro does no longer work. Symptoms are that the on the first tool change after program start always the selected tool is the current tool. On subsequent tool changes I always need to issue the tool chance to have to right tool set.
Does anybody has an idea what might be the problem?
Thanks in advance
Mark
Re: M6 macro in 4.2.0-3233
« Reply #1 on: March 03, 2017, 03:04:41 PM »
I think found the problem.
I use to change the tool manually by putting "T12M6" as a single line in MDI.
After changing the "Tool Change Type" to "T on M6 line is tool to use" every works as expected.
« Reply #2 on: April 11, 2022, 08:33:58 AM »
Are you still around?
Can you be more specific on how you fixed this?
