Hello Guest it is November 21, 2026, 03:34:37 PM
Author Topic: Connecting a 5 Volt Probe  (Read 16434 times)
« on: March 01, 2017, 06:10:51 PM »
Hello
I have a probe that has a 5 volt output that goes to zero when it is active. Can this be connected to the Integra and what would be the best way to do this?
Steve
Re: Connecting a 5 Volt Probe
« Reply #1 on: March 02, 2017, 11:27:45 AM »
Hello Steve,
For a 5 Volts probe, you can use pin12 on J10 of the Integra as this is a TTL Digital Input.
Make sure you power the probe with the 5Volts available on J11.
-Marc
Vital System Inc.
« Last Edit: March 02, 2017, 02:43:48 PM by Vital System Support »
« Reply #2 on: March 02, 2017, 01:47:06 PM »
Thank You
« Reply #3 on: March 02, 2017, 02:42:46 PM »
« Reply #4 on: June 01, 2017, 02:45:18 PM »
How do you access the state of J10 pin12? This is listed as "reserved" in the manual and there is no description of how to access the state?
« Reply #5 on: June 01, 2017, 07:45:33 PM »
Sorry pin12 is not mapped in the software.  however you can use other pins on J10, eg 6,7,8, and 9.  These are already mapped to HiCON port 14 pins 4,2,0, and 6.
Use a simple switch or an open collector / open drain type output to drive these pins to ground / 0v.  They are pulled up inside the unit to 3.3v, so your external output will just pull it down. To verify your output is safe for integra, take a 4.7K 1/4w resister, tie one end to the output, and the other end of the resister to 3.3volts on J6 (2nd pin from Ethernet port, label is wrong on it, should say 3.3v).  turn on the output, it should read 0 volts. turn off the output, it should read 3.3volts.
regards.
Rufi
« Last Edit: June 02, 2017, 01:46:58 PM by Vital System Support »
« Reply #6 on: June 02, 2017, 06:06:22 PM »
I noticed that pin12 is actually showing in the diagnostics screen when I sink that pin as well. Is there any reason that I can't use this as an input in my pendant construction? it appears to be mappable.
« Reply #7 on: June 02, 2017, 06:10:12 PM »
yeah if it does show up in the diag window then go for it.  Which controller model are you testing with?
