Hello Guest it is November 22, 2026, 08:07:17 AM
Author Topic: MENU Problem  (Read 8128 times)
MENU Problem
« on: February 23, 2017, 10:09:21 PM »
Hello,
I have two computers to do milling using Mach3.
Let me give them temporary names as PA and PB.
Both PA and PB are also running on Windows 7.
The problem is that the following menus are not working on PA.
Completely no response. No window appears.
 Config -> Motor Tuning
  Function Cfg's -> Calibrate Spindle...
  Function Cfg's -> ScrewMapping
A common point is that these menus are drawing graphs.
That must be the key.
But it's OK on PB.
Of course I checked both registry settings.
No difference.
Of course I copied Mach3 including .xml and other files from PB to PA.
Still problem.
PA hardware must have no problem,
So what is the cause? ???
If someone noticed possible solution, please let me know.
Best Regards.
  •  9,378 9,378
Re: MENU Problem
« Reply #1 on: February 24, 2017, 01:35:22 AM »
Try a fresh install of Mach3 on computer PA.
Re: MENU Problem
« Reply #2 on: February 26, 2017, 10:25:43 PM »
Yeah, you are right!
I tried a fresh install and it works well.
I wonder why I didn'd do such a simple and basic operation.
Any way, thanks a lot!
Incidentally, I have another menu problem as follws:
https://www.machsupport.com/forum/index.php/topic,31090.0.html
If you knew something good, let us know.
