Mach Discussion => General Mach Discussion => Topic started by: Samrai on February 23, 2017, 11:09:21 PM
Hello,
I have two computers to do milling using Mach3.
Let me give them temporary names as PA and PB.
Both PA and PB are also running on Windows 7.
The problem is that the following menus are not working on PA.
Completely no response. No window appears.
Config -> Motor Tuning
Function Cfg's -> Calibrate Spindle...
Function Cfg's -> ScrewMapping
A common point is that these menus are drawing graphs.
That must be the key.
But it's OK on PB.
Of course I checked both registry settings.
No difference.
Of course I copied Mach3 including .xml and other files from PB to PA.
Still problem.
PA hardware must have no problem,
So what is the cause? ???
If someone noticed possible solution, please let me know.
Best Regards.
Try a fresh install of Mach3 on computer PA.
Yeah, you are right!
I tried a fresh install and it works well.
I wonder why I didn'd do such a simple and basic operation.
Any way, thanks a lot!
Incidentally, I have another menu problem as follws:
https://www.machsupport.com/forum/index.php/topic,31090.0.html
If you knew something good, let us know.
