Hello Guest it is November 19, 2026, 04:06:27 AM
Author Topic: Homing and limits with ESS Smooth stepper and Mach Turn  (Read 6987 times)
« on: February 23, 2017, 10:13:45 AM »
Using Mach Turn and ESS
I just found out that automatic setup for homing and limit switches only applies to Parallel port boards. ??
Is there a way to do this using Smooth Stepper ??
What is the correct configuration of these switches for lathe operation ?
How can I set Z++, Z-- and  Z home switches for my lathe ?
How can I set X++, X- and X home switches for my lathe ?
I will used two switches for my Z axis and wire them in series.
One step at a time!
