Hello Guest it is November 23, 2026, 09:47:44 PM
Author Topic: Simple MPG hookup to Mach3  (Read 11905 times)
« on: June 14, 2007, 08:11:47 AM »
What is thi simplest way to conect an MPG to Mach3
I have a HP HEDS-5500 H14 encoder with 5 pins.
Do I need some form of interface or can this be done directly through
my Hobby CNC PRO board.
Bill Files
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Simple MPG hookup to Mach3
« Reply #1 on: June 14, 2007, 11:54:51 AM »
Hi, Bill
Gnd and 5 volts, Set up Config, Ports & Pins, Encoder/MPG's, Enable "MPG 1", Assign Ports and Pick Pin #'s for A & B inputs.
Your encoder count may be high, But you can use counts/unit to adjust it, Anyway it's a start, The 5th wire is probably "I" index not used.
Tab Key, Jog Mode select MPG, Alt A select Axis.
Hope this Helps, Chip
« Reply #2 on: June 16, 2007, 08:38:24 AM »
Hi Chip,
Thanks for the response.
I checked the pin specs on the encoder and yes there is, 0v, 5v, A, B, * pins
I have made the housing and the wheel has 50 detents.
The encoder is HP HEDS-5500--H14.
I will install 3 buttons on the control panel for changing Axes and use key grabber to activate them.
CNC is complicated enough so I use the K.I.S.S principle where possible.
RGDS
Bill Files
