Hello Guest it is October 20, 2026, 02:50:10 PM
Author Topic: Pause and re-start not working correctly  (Read 9217 times)
« on: February 07, 2017, 06:54:57 AM »
Seem to be having trouble with pause/re-starting Gcode and wondered if anyone else has seen this problem and perhaps have a solution. It doesn't happen every time but this is the second instance where the cutter has gouged a job after restarting from hitting the space bar. If i'm going to pause the router, I try to pause on a straight cut and this morning it continued in the same direction at the correct height after re-start but then removed a radius turning it into a chamfer then continued on the same line straight through the stock!
The other day I had a job with a long machine time and nervously stopped a started about four times without a problem. I thought the first time was just a one off and then it happened again today.
Any solutions/advice would be appreciated.
Steve.
Offline Davek0974
  •  2,606 2,606
Re: Pause and re-start not working correctly
« Reply #1 on: February 07, 2017, 08:05:16 AM »
The only time i have managed to get this to work is to press Feed-Hold then when the motion stops I press stop, to get going again i used Run From Here iIIRC
I hate doing it though and really try not to.
« Reply #2 on: February 07, 2017, 08:16:40 AM »
Dave,
Thanks for the feedback. After doing a few searches I found a piece on the SmoothStepper site(I'm using SmoothStepper) that describes a similar problem and they recommend installing an older more stable version of Mach3. I'm currently on 066 and they say 062 is better.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: February 07, 2017, 08:27:20 AM »
062 seems to be the "go to" version for Mach3
