Hello Guest it is November 19, 2026, 04:28:20 AM
Author Topic: Lathe Tool Turret Change M6  (Read 10661 times)
« on: February 04, 2017, 04:26:33 PM »
Does anyone have a working lathe turret tool change macro they are willing to share? I'm new to LUA script and have no clue where to start with writing my own code.
Re: Lathe Tool Turret Change M6
« Reply #1 on: February 07, 2017, 06:37:17 AM »
So far this is what I have. Thanks to Dan Mauch for sharing his tool changer macro.
 My tool changer is a ratcheting type with 8 positions.
 Right now it will change tools if the next tool is a higher number(CW move), If it is a lower number it wants to spin CCW against the ratcheting mechanism. I'd like to be able to home the C axis and then do the tool change. I haven't figured out how to make that work, it will Home the C Axis but then it wont do the tool change after.
-- Mach4Turn 8 positon tool Turret
 function m6()
 inst = mc.mcGetInstance()
 selectedtool = mc.mcToolGetSelected(inst)
 currenttool = mc.mcToolGetCurrent(inst)
 Ulock = 10    --'  Sets the Unlock Movement in Degrees Value
 Rlock = 10   -- ' Sets the Relock Movement in Degrees Value
 T1SafePosX =  2.25
 T1SafePosZ =  1.5
  if (selectedtool > 8) or (selectedtool < 1) then
    --DoButton(3)  --'Stop Program Run
    mc.mcCntlSetLastError(inst,"Program Stopped due to Tool Number Out of Range")
      do return end
      end
 if (selectedtool == currenttool) then
     mc.mcCntlSetLastError(inst,"Tool is the same NO tool change needed")
    do return end
    end
 local Tp = 0      --' Zero's the Tool Positon values DO NOT CHANGE
 --'------------------- Move to Safe Tool Position -----------
 mc.mcCntlSetLastError(inst," Move to Tool Safe Pos")
 mc.mcCntlGcodeExecuteWait(inst, "G1 F30 X" .. T1SafePosX);
 mc.mcCntlGcodeExecuteWait(inst, "G1 F40 Z" .. T1SafePosZ);
mc.mcCntlSetLastError(inst,"Safe XZ Move Completed")
 --'------ Begin Tool Change , UNLOCK turret --------------
 mc.mcCntlSetLastError(inst," Tool Turret UNLOCKING ")
 --mc.mcCntlGcodeExecuteWait(inst, " G91");   --'Set to INC
 mc.mcCntlGcodeExecuteWait(inst, " G52 C0");
 mc.mcCntlGcodeExecuteWait(inst, " G00 C " ..Ulock);    --'  Unlock turret
 --'------ Select Tool ------------------------------------
 if (selectedtool == 1) then
  mc.mcCntlSetLastError(inst,"Moving to Tool# " ..selectedtool )
    if (selectedtool > currenttool) then
       Moves =  selectedtool - currenttool
       Moves = (Moves * 45)
         mc.mcCntlSetLastError("  G00 C" ..Moves);
    end
         if (selectedtool < currenttool) then
               Moves = ((8 - currenttool) + selectedtool)
        mc.mcCntlSetLastError(" G00 C " ..Moves);
    end
    Tp = 0
       mc.mcCntlSetLastError(inst,"Tool#1 Loaded")
    end
    if (selectedtool == 2) then
        mc.mcCntlSetLastError(inst, "Moving to Tool# " ..selectedtool )
           mc.mcCntlGcodeExecuteWait(inst, " G00 C" ..Moves);
    end
                mc.mcCntlGcodeExecuteWait(inst, " G00 C " ..Moves);
    end
     Tp = 45
       mc.mcCntlSetLastError(inst,"Tool#2 Loaded")
    end
 if (selectedtool == 3) then
    end
    end
   Tp = 90
      mc.mcCntlSetLastError(inst, "Tool#3 Loaded")
    end
    if selectedtool == 4 then
        if selectedtool > currenttool then
    end
         if selectedtool < currenttool then
     end
   Tp = 135
       mc.mcCntlSetLastError(inst,"Tool#4 Loaded")
    end
 if (selectedtool == 5) then
    end
    end
    Tp = 180
   end
 if (selectedtool == 6) then
    end
    end
    Tp = 225
   end
 if (selectedtool == 7) then
    end
    end
    Tp = 270
   end
 if (selectedtool == 8) then
    end
    end
    Tp = 315
   end
--'------------ end Tool Change ------------------------
mc.mcCntlSetLastError(inst," Tool Turret LOCKING ")
mc.mcCntlGcodeExecuteWait(inst, " G00 H-" ..Rlock ); --   ' Lock Turret
mc.mcCntlGcodeExecuteWait(inst,  "G52 C" ..Tp);
--mc.mcCntlGcodeExecuteWait(inst,  "G90");   --' Reset to ABS
     tool = selectedtool
 mc.mcToolSetCurrent(inst, selectedtool)
    m6()
    end
end
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: February 08, 2017, 05:58:27 PM »
I have not tried this but I would think this is all the code you need.
 function m6()
 T1SafePosX =  2.25
 T1SafePosZ =  1.5
       do return end
end
    do return end
end
 mc.mcCntlGcodeExecuteWait(inst, " G92 C0");
    else
    end
Moves = (Moves * 45) + Ulock
mc.mcCntlGcodeExecuteWait(inst, " G00 C-" ..Rlock ); --   ' Lock Turret
mc.mcCntlGcodeExecuteWait(inst,  "G92 C0");
tool = selectedtool
   m6()
end
end
« Reply #3 on: February 08, 2017, 07:31:13 PM »
Thanks! I'll give it a shot!
« Reply #4 on: February 20, 2017, 09:16:04 AM »
I had to change the moves to G53 instead of G0 on the C axis, also added  turret = mc.mcAxisGetMachinePos(inst, 5).  Now the tool changer works like it should.
-- Mach4Turn Ratcheting Tool Turret
 function m6()
 Ulock = 10 -- ' Sets the Unlock Movement in Degrees Value
 Rlock = 5 -- ' Sets the Relock Movement in Degrees Value
 T1SafePosX =  2
 T1SafePosZ =  1.5
      do return end
      end
    do return end
    end
 mc.mcCntlGcodeExecuteWait(inst, "G53 X" .. T1SafePosX);
 mc.mcCntlGcodeExecuteWait(inst, "G53  Z" .. T1SafePosZ);
            Turns = ((8 - currenttool) + selectedtool)
            Moves = turret + Ulock + (Turns * 45)
            mc.mcCntlGcodeExecuteWait(inst, " G53 C " ..Moves);
end
            Turns =  (selectedtool - currenttool)
            mc.mcCntlGcodeExecuteWait(inst, " G53 C" ..Moves);
    end
mc.mcCntlSetLastError(inst, "Tool#1 Loaded")
elseif (selectedtool == 2) then
mc.mcCntlSetLastError(inst, "Tool#2 Loaded")
elseif (selectedtool == 3) then
elseif (selectedtool == 4) then
mc.mcCntlSetLastError(inst, "Tool#4 Loaded")
elseif (selectedtool == 5) then
mc.mcCntlSetLastError(inst, "Tool#5 Loaded")
elseif (selectedtool == 6) then
mc.mcCntlSetLastError(inst, "Tool#6 Loaded")
elseif (selectedtool == 7) then
mc.mcCntlSetLastError(inst, "Tool#7 Loaded")
elseif (selectedtool == 8) then
mc.mcCntlSetLastError(inst, "Tool#8 Loaded")
end
mc.mcCntlGcodeExecuteWait(inst, " G52 C0" );
     tool = selectedtool
    m6()
    end
end
  •  2,785 2,785
« Reply #5 on: February 25, 2017, 09:52:51 PM »
Your welcome  :D
