Mach Discussion => Mach4 General Discussion => Topic started by: RootbeerFLHX on February 04, 2017, 05:26:33 PM
Does anyone have a working lathe turret tool change macro they are willing to share? I'm new to LUA script and have no clue where to start with writing my own code.
So far this is what I have. Thanks to Dan Mauch for sharing his tool changer macro.
My tool changer is a ratcheting type with 8 positions.
Right now it will change tools if the next tool is a higher number(CW move), If it is a lower number it wants to spin CCW against the ratcheting mechanism. I'd like to be able to home the C axis and then do the tool change. I haven't figured out how to make that work, it will Home the C Axis but then it wont do the tool change after.
-- Mach4Turn 8 positon tool Turret
function m6()
inst = mc.mcGetInstance()
selectedtool = mc.mcToolGetSelected(inst)
currenttool = mc.mcToolGetCurrent(inst)
Ulock = 10 --' Sets the Unlock Movement in Degrees Value
Rlock = 10 -- ' Sets the Relock Movement in Degrees Value
T1SafePosX = 2.25
T1SafePosZ = 1.5
if (selectedtool > 8) or (selectedtool < 1) then
--DoButton(3) --'Stop Program Run
mc.mcCntlSetLastError(inst,"Program Stopped due to Tool Number Out of Range")
do return end
end
if (selectedtool == currenttool) then
mc.mcCntlSetLastError(inst,"Tool is the same NO tool change needed")
do return end
end
local Tp = 0 --' Zero's the Tool Positon values DO NOT CHANGE
--'------------------- Move to Safe Tool Position -----------
mc.mcCntlSetLastError(inst," Move to Tool Safe Pos")
mc.mcCntlGcodeExecuteWait(inst, "G1 F30 X" .. T1SafePosX);
mc.mcCntlGcodeExecuteWait(inst, "G1 F40 Z" .. T1SafePosZ);
mc.mcCntlSetLastError(inst,"Safe XZ Move Completed")
--'------ Begin Tool Change , UNLOCK turret --------------
mc.mcCntlSetLastError(inst," Tool Turret UNLOCKING ")
--mc.mcCntlGcodeExecuteWait(inst, " G91"); --'Set to INC
mc.mcCntlGcodeExecuteWait(inst, " G52 C0");
mc.mcCntlGcodeExecuteWait(inst, " G00 C " ..Ulock); --' Unlock turret
--'------ Select Tool ------------------------------------
if (selectedtool == 1) then
mc.mcCntlSetLastError(inst,"Moving to Tool# " ..selectedtool )
if (selectedtool > currenttool) then
Moves = selectedtool - currenttool
Moves = (Moves * 45)
mc.mcCntlSetLastError(" G00 C" ..Moves);
end
if (selectedtool < currenttool) then
Moves = ((8 - currenttool) + selectedtool)
mc.mcCntlSetLastError(" G00 C " ..Moves);
end
Tp = 0
mc.mcCntlSetLastError(inst,"Tool#1 Loaded")
end
if (selectedtool == 2) then
mc.mcCntlSetLastError(inst, "Moving to Tool# " ..selectedtool )
mc.mcCntlGcodeExecuteWait(inst, " G00 C" ..Moves);
end
mc.mcCntlGcodeExecuteWait(inst, " G00 C " ..Moves);
end
Tp = 45
mc.mcCntlSetLastError(inst,"Tool#2 Loaded")
end
if (selectedtool == 3) then
end
end
Tp = 90
mc.mcCntlSetLastError(inst, "Tool#3 Loaded")
end
if selectedtool == 4 then
if selectedtool > currenttool then
end
if selectedtool < currenttool then
end
Tp = 135
mc.mcCntlSetLastError(inst,"Tool#4 Loaded")
end
if (selectedtool == 5) then
end
end
Tp = 180
end
if (selectedtool == 6) then
end
end
Tp = 225
end
if (selectedtool == 7) then
end
end
Tp = 270
end
if (selectedtool == 8) then
end
end
Tp = 315
end
--'------------ end Tool Change ------------------------
mc.mcCntlSetLastError(inst," Tool Turret LOCKING ")
mc.mcCntlGcodeExecuteWait(inst, " G00 H-" ..Rlock ); -- ' Lock Turret
mc.mcCntlGcodeExecuteWait(inst, "G52 C" ..Tp);
--mc.mcCntlGcodeExecuteWait(inst, "G90"); --' Reset to ABS
tool = selectedtool
mc.mcToolSetCurrent(inst, selectedtool)
if (mc.mcInEditor() == 1) then
m6()
end
end
I have not tried this but I would think this is all the code you need.
function m6()
T1SafePosX = 2.25
T1SafePosZ = 1.5
do return end
end
do return end
end
mc.mcCntlGcodeExecuteWait(inst, " G92 C0");
else
end
Moves = (Moves * 45) + Ulock
mc.mcCntlGcodeExecuteWait(inst, " G00 C-" ..Rlock ); -- ' Lock Turret
mc.mcCntlGcodeExecuteWait(inst, "G92 C0");
tool = selectedtool
m6()
end
end
Thanks! I'll give it a shot!
I had to change the moves to G53 instead of G0 on the C axis, also added turret = mc.mcAxisGetMachinePos(inst, 5). Now the tool changer works like it should.
-- Mach4Turn Ratcheting Tool Turret
function m6()
Ulock = 10 -- ' Sets the Unlock Movement in Degrees Value
Rlock = 5 -- ' Sets the Relock Movement in Degrees Value
T1SafePosX = 2
T1SafePosZ = 1.5
do return end
end
do return end
end
mc.mcCntlGcodeExecuteWait(inst, "G53 X" .. T1SafePosX);
mc.mcCntlGcodeExecuteWait(inst, "G53 Z" .. T1SafePosZ);
Turns = ((8 - currenttool) + selectedtool)
Moves = turret + Ulock + (Turns * 45)
mc.mcCntlGcodeExecuteWait(inst, " G53 C " ..Moves);
end
Turns = (selectedtool - currenttool)
mc.mcCntlGcodeExecuteWait(inst, " G53 C" ..Moves);
end
mc.mcCntlSetLastError(inst, "Tool#1 Loaded")
elseif (selectedtool == 2) then
mc.mcCntlSetLastError(inst, "Tool#2 Loaded")
elseif (selectedtool == 3) then
elseif (selectedtool == 4) then
mc.mcCntlSetLastError(inst, "Tool#4 Loaded")
elseif (selectedtool == 5) then
mc.mcCntlSetLastError(inst, "Tool#5 Loaded")
elseif (selectedtool == 6) then
mc.mcCntlSetLastError(inst, "Tool#6 Loaded")
elseif (selectedtool == 7) then
mc.mcCntlSetLastError(inst, "Tool#7 Loaded")
elseif (selectedtool == 8) then
mc.mcCntlSetLastError(inst, "Tool#8 Loaded")
end
mc.mcCntlGcodeExecuteWait(inst, " G52 C0" );
tool = selectedtool
m6()
end
end
Your welcome :D
