Hello Guest it is November 22, 2026, 04:38:53 PM
Author Topic: Change Wiring  (Read 9438 times)
Offline kolias
  •  1,165 1,165
Change Wiring
« on: February 04, 2017, 12:58:44 PM »
My setup with the G540 is all complete and works fine but the motors direction is not the way I wanted. Like when I press the page UP keyboard button the Z axis goes down. I know I can change the Active Low from green to red or from red to green or perhaps from the Homing / Limits page click on the Reverse column?
It’s also easy for me to switch the motor wiring but I don’t know which pair. From the attached Keling wiring schematic which pair of wires will change the motor direction?
Nicolas
Re: Change Wiring
« Reply #1 on: February 04, 2017, 04:15:26 PM »
just change one pair, keep the blue and red together and the green and yellow together, but swap the terminals
in which they go.
Offline kolias
  •  1,165 1,165
Re: Change Wiring
« Reply #2 on: February 04, 2017, 05:16:19 PM »
Thanks Craig, will give it a try
Nicolas
Re: Change Wiring
« Reply #3 on: February 04, 2017, 08:36:19 PM »
Checking the Reverse column is a lot easier than changing wires.
Offline kolias
  •  1,165 1,165
Re: Change Wiring
« Reply #4 on: February 04, 2017, 09:10:40 PM »
You are right Gerry, wiring was not as easy as i thoought and the Reverse column did the trick, thanks
Nicolas
