Hello Guest it is November 23, 2026, 05:24:27 AM
Author Topic: Mach not responding  (Read 11493 times)
Offline Toad
  •  58 58
Mach not responding
« on: January 19, 2017, 02:48:08 PM »
Good day all,
My keypad for Mach has quit working.
I tried setting up a Shuttle Pro for Mach. Never did get it working correctly, but during the process, I went back to Mach and discovered the Eithernet-smoothstepper had quit working also.  I uninstalled the the Shuttle program, and tried again. I finally got the Smooth-Stepper working.
The PC will run a program now, but the Mach screen can not be controlled by the keypad. I tried reloading Mach thinking I may have deleted something I should not have, but no change. Your assistance in getting it fixed would be much appreciated.
Toad.
  •  9,378 9,378
Re: Mach not responding
« Reply #1 on: January 20, 2017, 12:34:39 AM »
Although you re-installed Mach3 you may still have a corrupt .xml file.
From the Mach3 / xmlbackups folder select an xb# file from a date before the problem occurred. Copy it and change the file extension to .xml then copy it into the Mach3 folder.
Offline Toad
  •  58 58
« Reply #2 on: January 21, 2017, 01:25:57 PM »
Thanks for your help,
I got the machine responding when I use the Tab control, but if I switch back to the keyboard, nothing responds. All works when I run a program, just keyboard is dead as far as moving Axes XYX. I tried going to Config hot keys, but it didn't  make any difference.
Your thoughts?
Ty948
Offline Toad
  •  58 58
« Reply #3 on: January 21, 2017, 01:46:01 PM »
Also, when I hit spindle stop, it slows down to 120 RPM, but does not stop till I hit the stop button.
Offline Toad
  •  58 58
« Reply #4 on: January 21, 2017, 02:37:35 PM »
I got the keyboard responding!!!!!!!!!!!!
Offline Toad
  •  58 58
« Reply #5 on: January 21, 2017, 02:39:24 PM »
Now the only thing left is the spindle not stopping completely.
