Hello Guest it is November 22, 2026, 09:11:27 AM
Author Topic: event driven serial control and modbus  (Read 26174 times)
« on: June 11, 2007, 07:43:11 AM »
Hello,
I need to use both modbus and event driven serial control (port & pins config)
However if i switch on the serial function, the modbus is disabled, even tough there ports are set up different.
Is this normal? (then i have a problem) or has it never been detected. i'm using Mach 3 version 2.0.0.17
anyone?
Kris.
Logic takes you from A to B, imagination takes you anywhere
Re: event driven serial control and modbus
« Reply #1 on: June 11, 2007, 09:03:29 AM »
I think you are the first to do that :(..
I will ask Art about it this week
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 12, 2007, 04:13:49 AM »
Well eh,
at least i can say that i'm a pioneer !  ;D
a statue is perhaps exaggerated  :D
enough foolishness.
I really hope this one is solvable.
I asked you a question about modbus over TCP last year, if ther's any progress in this area, that would also solve the problem.
Hope to here from you soon.
Kris
« Last Edit: June 12, 2007, 04:20:04 AM by krisverheyen »
« Reply #3 on: June 17, 2007, 03:27:40 PM »
Public Sub reply
While MsgBox  ("Hello Brian, " & vbcrlf & _
"Did you get a chance to talk to Art about this problem yet?" ,vbYesNo) =vbNo
 KeepOnWaiting ....
Wend
End Sub
 ::) :D :o ;D ::)
« Reply #4 on: June 19, 2007, 04:36:44 PM »
Hello Art or Brian,
Did you had a chance to discuss this problem yet?
I'm stuck at the moment.
Thank you
Kris
« Reply #5 on: June 27, 2007, 04:36:51 PM »
« Reply #6 on: July 13, 2007, 09:07:05 AM »
Hello,
Any chance i can get an answer about my problem?
pleeeeeaaaase.
Kris
« Reply #7 on: July 13, 2007, 09:15:29 AM »
You can't do both on the same machine ;(
Sorry
www.machsupport.com
« Reply #8 on: July 13, 2007, 09:35:03 AM »
OK,
I'll have to find a other solution.
Kris
« Reply #9 on: July 22, 2007, 01:14:30 PM »
Looks like that limitation may have just been lifted :) Test the newest version to see if it works for you :)
Brian
www.machsupport.com
