Hello
Guest
it is
November 13, 2026, 10:23:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 Starting to behave erratically!
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 Starting to behave erratically! (Read 9144 times)
Dougie
3
on:
January 07, 2017, 08:07:48 AM »
HELP! We are half through our biggest job (600 sheets of 18mm ply) and Mach 3 is starting to behave erratically.
There are 2 symptoms:
1) The 2 X drive stepper motors appear to go out of sync when returning to fixture zero causing the X carriage to jerk violently and derail.
2) Intermittently, starts cutting a file too early (ie short of X destination) on the X axis all the while making bad noise??
Can anyone help this operator. This happens about every 4th sheet?
Look forward to any suggestions. Thanks.
ger21
6,295
Re: Mach3 Starting to behave erratically!
Reply #1 on:
January 07, 2017, 08:36:53 AM »
Loose wires, failing drive or motor? Carefully check both X axis motors and drives, and all wiring that they use.
Dougie
3
Reply #2 on:
January 07, 2017, 08:43:48 AM »
Thanks Gerry
The one other main issue is when tracking to fixture home, that's when the X axis plays up. So will do the checks and report back.
Thanks for your speedy response.
Highspeed1964
126
Reply #3 on:
January 09, 2017, 05:48:21 PM »
With it being such a large job, my guess would be mechanical. Parts tend to wear out, although it could also be loose wires like Gerry said. But motors and mechanical wear would be where I start after checking those wires.
Highspeed
Print
Pages:
1
Go Up
« previous
next »
