Hello
Guest
it is
November 13, 2026, 10:33:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Axis dros off after loading Gcode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Axis dros off after loading Gcode (Read 10479 times)
Charlie_M
189
on:
December 22, 2016, 07:57:24 AM »
Hi here is what is going on. I had to reinstall my OS(XP). I reinstalled Mach3 version 3.043.062. Setup everything. Loaded a gcode file and I noticed my z axis Dro was off. I verified this by measuring the movement and comparing it to the dro reading. I moved ~ 1 inch(measured) and the dro reading was .045. I checked the settings in mortor tuning and everything was correct. I closed the file and restarted Mach3. I retested and measured and it was spot on. I reloaded the Gcode file and it was off my a mile. anyone have any idea what could cause this?
Charlie
Regards
Charlie M.
Tweakie.CNC
9,377
Super Kitty
Re: Axis dros off after loading Gcode
Reply #1 on:
December 22, 2016, 09:31:44 AM »
Check your Gcode file.
Just as an example it could be scaling the Z axis or perhaps changing the coordinate system, offsets, etc.
ger21
6,295
Reply #2 on:
December 22, 2016, 09:47:44 AM »
Make sure your Native Units match the units you set up your machine to.
This can happen when Native Units is set to mm's, but you setup your machine with inch parameters.
Mach3 defaults to mm's as the Native Units.
Charlie_M
189
Reply #3 on:
December 22, 2016, 11:11:38 AM »
Thanks for the relies. I think Gerry Guessed it. I changed the native units from mm to inch and it seems ok now. I must have missed that setting.
Regards
Charlie M.
Print
Pages:
1
Go Up
« previous
next »
