Hello Guest it is October 22, 2026, 03:34:28 PM
Author Topic: Big Tex screen set  (Read 15301 times)
Big Tex screen set
« on: December 08, 2016, 01:10:43 AM »
Hi All,
I have problem with new installed Mach3 and Big Tex Screen set.   Once i Hit Z plate offset, the probing doing good, but after touch finished, the Z going down straight again(only can stop it with hit reset/stop button)  Any one have solution about this?
I used previous version(few year ago version) with no problem, the old pc was damage and i have install everything new,now face this problem.
Best Regards,
Hawk
Offline dude1
  •  1,253 1,253
Re: Big Tex screen set
« Reply #1 on: December 08, 2016, 03:39:01 AM »
Its this if home and work are under 1 inch 25 mm apart it may crash what version of the blue screen are you useing, and I have a code that works on his ver 3.2.
the thing what does it there is no retract in the code
« Reply #2 on: December 08, 2016, 03:56:39 AM »
Are you mean use Mach version 3.2  will work fine with this blue screen set?
Sorry, my English not really good.
« Reply #3 on: December 08, 2016, 08:08:27 AM »
Also, many Chinese motion controllers can cause this.
« Reply #4 on: December 08, 2016, 08:12:45 AM »
Before that is work fine with previous version.
« Reply #5 on: December 08, 2016, 09:12:41 AM »
Don't use 3.043.066, as it also can cause problems with probing.
Try 3.043.062.
« Reply #6 on: October 02, 2017, 08:12:14 AM »
I have a problem with Mach 3, Big Tex screen and The Maker Guide Triple Edge Finder. I can replace the existing code for the Z-axis probe and it touches fine.
However, when I try to get it to find the center of the circle for finding the edge of the material, it scans left finds the edge. Scans right and finds the edge but it returns after finding the right edge way over to left and moves the finder off the edge.
My Mach3Mill.xml is from the manufacturer of the CNC and replaces the default one.
I have created a new profile (6090a) and overwritten its' xml file with the contents of the Mach3Mill.xml so I get all the settings....
Is there some setup I am missing. I am using mm as my units and a JCut 6090A CNC Router.
« Reply #7 on: April 13, 2019, 05:36:08 AM »
Where can this screenset be got. The link on the mach3 website does not work.
Offline ZASto
  •  434 434
« Reply #8 on: April 13, 2019, 12:33:46 PM »
Used to have 3.2 but then i bought from Big-tex 3.4.
Unfortunatelly, I deleted 3.2 installation :(
If I find it, I will put 3.2 here
My personality is who I am.
