Hello Guest it is November 13, 2026, 09:40:24 AM
Author Topic: Trying to create a new profile and shortcut for Mach3 Turn, not cooperating  (Read 10962 times)
Hello,
Has anybody had difficulty creating a secondTurn profile and deskto icon from the Mach3 launcher?  I pick my current Turn profile to clone and what I keep getting a profile one for Mill that needs all the settings repopulated and  no icon appears anywhere that I can find.  Has anyone run into this?  Is there a way to fix it?
I'm trying to work around an issue with BobCAD where arcs come into Mach3 backwards, you need to click a box in Mach3 to reverse them but it blows up all the built in Turn Wizard code generating functions.  Building separate BobCAD and a Turn Wizard profiles is apparently the fix.  This is a long term known BobCAD issue with Mach3.  Visual Turn is looking better and better all the time.
Any help would be appreciated, thanks.
Damon
Offline Chaz
  •  48 48
Same problem, did you solve it?
Just  copy of the 1st xml file and rename the copy to a different name.
Offline Chaz
  •  48 48
Found an easier way, go to screens, ensure it's not filtered to mill only, sorted.
