Mach Discussion => General Mach Discussion => Topic started by: eatsteelnotbutter on November 20, 2016, 08:13:16 PM
Hello,
Has anybody had difficulty creating a secondTurn profile and deskto icon from the Mach3 launcher? I pick my current Turn profile to clone and what I keep getting a profile one for Mill that needs all the settings repopulated and no icon appears anywhere that I can find. Has anyone run into this? Is there a way to fix it?
I'm trying to work around an issue with BobCAD where arcs come into Mach3 backwards, you need to click a box in Mach3 to reverse them but it blows up all the built in Turn Wizard code generating functions. Building separate BobCAD and a Turn Wizard profiles is apparently the fix. This is a long term known BobCAD issue with Mach3. Visual Turn is looking better and better all the time.
Any help would be appreciated, thanks.
Damon
Same problem, did you solve it?
Just copy of the 1st xml file and rename the copy to a different name.
Found an easier way, go to screens, ensure it's not filtered to mill only, sorted.
